LA950A FEL leg stands
heppeone
L3750dt w/fel, woods box blade, woods rake, woods yard roller
Oct 24, 2014
22
murrells inlet, sc
Have an older 3750 with a LA950A loader on it, the fel does not have permanently attached leg stands that swing down like the new model fels, it has a 4 piece system that I cant figure out by myself. The 4 piece system consists of two identical 2 piece sets, two are stored above the loader frame just in front of the steering wheel and the other set is stored on the sides of tractors frame.
I have called my dealer, they offered no good usable advise. Also been checking online for manual, advise or videos. All the videos I've found show newer models that have swing down legs, and have been unable to find manual in search engines.
Sure that once I see how it goes I'll feel silly for not figuring it out by myself, but oh well, can swallow my pride.
Thanks in advance for any advise.
mdhughes
L3901DT
Dec 10, 2014
1,324
999
Ste Geneveive county, MO
I think this might help you out. Looks like one of the pieces connect to the bucket and the other to the frame and then to the first piece. Not sure what the measurements are about.
ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
May 10, 2013
143
Suffield, CT
I've got the same set-up and it is a head-scratcher every time I take the loader off. I lift the loader bucket up about a foot off the floor to put the bars on and the position of the bucket on the ground afterward is crucial.
That last picture shows the set up well but let me know if you need any other pictures.
heppeone
Oct 24, 2014
22
murrells inlet, sc
Was searching for another article and ran back into this one. Never thanked you for the picture, thank you. I***8217;ve taken loader off only a couple times cause it really is kind of a pain. For you or anyone else, but of advise I***8217;ve found that works for me, but maybe there***8217;s an actual procedure, I use a jack to lift front brace off then prop it up like in picture. Not sure it***8217;s designed that way. Anyone have advise?
