la526 loader lifts slowly
oldpete58
la526 loader
Jul 10, 2025
9
the loader lifts slowly when lever fully down. lever 3/4 down lifts fine. when going down with loader feels like a hard spot then after that loader drops quickly. linkage looks fine.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,234
1,844
WestTn/NoMs
By 'lever' do you mean the 3ph control lever? If so, you probably need to adjust the feedback linkage so the 3pt doesn't go into relief when fully raised. What tractor is this on?
oldpete58
la526 loader
Jul 10, 2025
9
I'm talking lever to lift and lower bucket
5,188
The "hard spot" is the detent between the power down and gravity down (float) positions That is operating correctly..
What engine RPM are you using? Lowering and lifting speed will increase with higher engine speed.
May I suggedt you read yhe loader operating manual?. It covers these things in some detail.
5,188
the hard spot is very noticeable.was much smoother
Your engine wont run at 540 RPM. That is PTO speed which corresponds to about 2200 engine RPM.
The valve is fine. Sounds like your power beyond circuit is blocked. Do you have a backhoe or rear remotes on the tractor? Is the position control lever in a raised position?
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
146
252
St. Clair, MO.
Valve rarely goes bad. Possible restriction at the connection fittings.
5,188
have a back hoe
It would be helpful if you told us if the hoe is mounted or not 🙄
This loader issue is a common problem with Kubota tractors and frequently caused by a downstream blockage in the hydraulic circuit.
Check your backhoe hydraulic couplers to make sure they are fully seated.
If the backhoe is mounted check ALL of the control levers to make sure they are centered. The outrigger control levers in particular have been a problem.
Make sure the position control lever is in the full down position and keep it there whenever the backhoe is mounted.
oldpete58
la526 loader
Jul 10, 2025
9
the lever that turns on my log splitter got moved slightly. problem solved
