La450 fel cylinder kit?
wblack
L2550 4WD with Loader
Oct 6, 2013
21
CHARLOTTE
Hey guys,
I am trying to find an illustrated parts list for the subject FEL. I need to rebuild all four cylinders. Does anyone know how to find it?
It's hard navigating Kubotas documents; haven't had any luck there, maybe I just don't know how to search it well enough.
Thanks in advance for your help.
Wes
coachgeo
Nov 16, 2012
2,460
35
Southern OH
Re: La450 fel cynilder kit?
Unfortunately like 99.9% of all bulletin boards you can't search for 3 letter combinations. So searching bulletin boards for FEL won't help. Search "Cylinder" and "Cylinders" maybe along "Loader" and "La450" might help.
If recall right, around here folk just take them to a hydraulic shop for rebuild or to have the shop put together a set of parts for the person to rebuild it themselves. Often a lot cheaper than going thru a local Tractor Repair/Parts shop.
wblack
Oct 6, 2013
21
CHARLOTTE
thanks coachgeo. i wished to have the parts in hand when we tear the cylinders down. i guess we may have to tear one down and take it to a shop to match parts.
wblack
Oct 6, 2013
21
CHARLOTTE
Took one of each cylinder off this afternoon and removed all the internals. I am happy to say that everything regarding the shafts and cylinders looked brand new. And why the one was leaking is obvious, the last or outer seal was dry-rotted.
There was slight wear on one of the guides inside, glad they're aluminum! My Dad will take everything to our local hydraulic shop in the morn and buy the replacement gaskets and o-rings.
Is there anything that I should keep in mind or do as we rebuild. This is the first time either of us has rebuilt one? Seems pretty cut and dry; but I am wondering what you guys use to lubricate the parts as we rebuild and how do you make sure everything is clean leaving no grit.
Thanks in advance!
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
Just make sure there is no grit in or on anything. I make fork lifts for a living big fork lifts. And we use STP on the packing to put them together. Just be careful not to pinch anything and u should be ok
WHMetalSmith
Kubota L2050 4whd with LA450S loader
Dec 22, 2020
Raleigh, NC
I’m rebuilding the bucket cylinders on my LA450S loader. Got the cylinder off. I need help with how to remove the end of the cylinder - there are two holes in the end - is a special spanner required to remove it, can I use a pipe wrench without hurting the function (I know it’ll make it ugly).
ruger1980
L4310 w/La682, L225
Oct 25, 2020
395
145
CNY
Yes you can use a pipe wrench but it will make it ugly as you say. The only issue is it may not spin the gland out if it is stuck too tight. A lttle heat on the barrel may help if it does not move.
Also do not clamp the barrel in the vise too tightly and when trying to turn the gland. Clamp the pin boss at the end of the cylinder.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,776
1,503
WestTn/NoMs
I haven't done a loader cylinder, but I found the easiest way to hold the head end on my backhoe cylinders was to reinstall that end with the pin. Actually, after the first couple I loosened the head before taking the cylinder off.
Somebody on here made an adjustable pin wrench. I'll try to find it.
Here it is. Post #16. This thread also shows a set of tools that are handy for installing the rod seal.
PapaJ
BX2680 - PFL1242 - RCK54 MMM - Fimco 3PH Sprayer - Trailer Mover
Apr 28, 2020
281
106
VA
I've did a few hundred cylinder rebuilds on old John Deere and Hyster fork trucks when I was in the Air Force. I used a ginormous pipe wrench. We had spanner wrenches, but they didn't work as good most times, and our vehicles were all assigned to Civil Engineering or munitions, who was going to trash them as soon as they got them, so no need to have them looking pretty.
WHMetalSmith
Dec 22, 2020
Raleigh, NC
Thanks, I used a pipe wrench and got it off.
