Howdy, thanks for all the great info on the forums (replies etc). I have a BX2200 with a LA211 Loader. It has served me well for quite a few years. Recently I had to replace quite a few hoses as they all went bad together (about 14 years old). After replacing them, everything worked fine, except I did not have power in the dump (uncurl) direction. It will dump slowly using gravity, but I cannot pickup the front end of the tractor any more (unless I drop the bucket to 90 deg to ground and use the lift arms entirely. I cannot grade or dig with this issue. Sometimes when I move the lever all the way to the right (power dump) it curls instead of dumps. I have swapped the loader arms up/down with the curl/dump hoses, and all the functions work except for dump (same problem). I swapped the QD's on the curl and dump (blue and red) lines, didn't fix it. I do hear a squeal when trying to dump (similar sound to when the mower lift level is up and I try to use the bucket. I have not pulled the pressure relief valve (I believe it is under the mower PTO attachment). Is that my next step, or is the curl/dump cylinder bad. Thanks for your help!
