LA210 boom arm weld in bushing/boss
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
Denver North Carolina
Anybody know where I can souce this weld in bushing/boss or do I need to just make one. I driled heated and still wont budge I want to just replace it thanks
4,717
Welcome aboard!!!!!
Wow…..that looks like an “interesting” project :unsure:
Looks like it was “stored" at the bottom of the ocean though…….
Unfortunately, I have no idea on where to buy one, but it sounds like you have the capability to make one.
Keep us up-to-date on how it turns out, and remember……….Pics, ….or it didn't happen(y):D
BX23-S,57 A-C D-14,
6,066
YIKES !!! have to wonder what the rest of the loader, heck whole tractor looks like !
You should ask Google about 'cylinder cross tubes'....
I can easily get these....
You'll have to measure what you need of course. If the loader was made in USA, it 'should' be Imperial an not Metric ??
Yooper
3901 LA525
May 31, 2015
1,703
865
NE Wisconsin
I agree with you 100% to replace it. Easy lathe job to make part if you have one or know someone that does. Final sizing of the bore should be done after welding it in.
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
Thanks for info on the cross tube that will probably be the ticket. Got the tractor for 2gs not running but was just the fuel pump but going through the whole thing. Here it is before tear down. 20251231_014446626_iOS.jpg 20251228_035431234_iOS.jpg 20260123_074413061_iOS.jpg the other side wasnt as bad. Ill keep you posted as I cut it out and replace. Thanks for the help. 20260123_212843077_iOS.jpg
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
937
912
E.
Thanks for info on the cross tube that will probably be the ticket. Got the tractor for 2gs not running but was just the fuel pump but going through the whole thing. Here it is before tear down.the other side wasnt as bad. Ill keep you posted as I cut it out and replace. Thanks for the help.
nice project... I'm no expert on this issue but FWIW..... Will you have to keep it in 2wd only due to the mis-matched tires?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
557
237
CNY
If you have an oxy acetylene cutting torch you could cut a couple kerfs the length of the pin/bushing. That would shrink it similar to what lancing a pin does. If talented enough with a torch you could even cut through the pin to the bushing without harming it.
I made new bushings for mine and mase them larger but turned the ID large enough to hold 1" leaf spring shackle bushings. when welding them in just use a long rod the same diameter of the pin and align them in the loader arms. The tolerances are not that tight on the bucket and arms so machining after welding is generally not needed unless you weld it in all cattywampus.
10,194
The tread style can be mismatched as long as the size is right. ;)
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
well I cut the booger out ground 20260124_043614763_iOS.jpg 20260124_043629228_iOS.jpg 20260124_043646930_iOS.jpg 20260124_043658712_iOS.jpg 20260124_043712647_iOS.jpg the outside knocked what was left of the insert out will clean it out a little more later. Orderd cross tube off ebay actuly 2 to do the other side as well. Ill update when parts get in could be awhile ice storm coming our way.
4,717
Looks great man!
I am "officially jealous" of your shop too. (y) (y) (y)
(although it is a little ‘too clean” for my taste ;);))
2,648
After seeing the RUST inside the loader arm, curious, if you can 'treat' it somehow to stop the rusting process ? Maybe some chemical treatment then a rust paint ?
If you want to you can look at gas tank repair kits that might work to remove the rust and paint the interior of the tube (assuming it could be rotated or sprayed on the interior surface. I would wait until after you weld it together before you get the paint applied (and probably the rust removed after welding?)
I just used a KBS system that cleaned and removed the rust well.
I know they also make some material that is poured into steel rudders to keep them from rusting. That might help now but I really don’t know.
Maybe something here would help?
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
Looks great man!
Took me fifty years to get the shop I wanted I still get it dirty but I am a clean freak so I clean up right after. 30x40 climate controled
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
Thanks for the insite. I got some of this when I redid a trailer recently and worked pretty good on the rust before paint.
10,194
Put a rod that runs from one side to the other to set them parallel to each other when you weld the bushing in.
