The engine I have is a V2403-CR-T---- but, when you for the information on the rest of the number I cant find what it means. that pat is, EF04.
Reading here there and everywhere it seems to buy parts I would use V2403-CR-TE04.
The EPA label plainly says V2403-CR-T-EF04.
I do know the V2403 is a 2.434 L (in.cu)
The -CR- is common rail
The -T- is for turbo
The EF04 I have no idea
The Block has a cast number of 2.434 with and ohm symbol. for the 2.434 L (in.cu)
The Block has a stamped number of V2403-7DD with 4-5 more #s i think it was 1181 or something like it.
The cast numbers on the head appear to be 30201 with another casting in a different location the is VIDI
with the given,
What does the TE04 mean on the end of my engine number?
What Motor # would I use to buy parts such as a rebuild kit?
What Motor # would I use to order a new engine?
with the given,
