We found a lubricant leak coming from the left front axle on our L5450. Removed wheel and oil seal cover. To our utter shock we found ALL the bolts that keep the Bevel Gear were unscrewed about a 1/2 inch. The inside portion of the oil seal cover displayed wear from the protruding bolt heads. This is the first time the cover has been removed during the tractors lifetime (it was purchased new). the manual indicates a 'Liquid Lock' needs to be applied if these bolts are removed (I assume this is prevent this exact situation). This leads one to suspect a failure to apply a 'Liquid Lock' at the factory.
Has anyone ever seen this situation?
Could these bolts come loose on their own (all of them)?
Pictures are enclosed to help clarify. A portion of the manual is also shown.
