L4740 - suspect glow plug problem. Advice welcomed.
Nick P
L4740 HST with various attachments
Oct 16, 2025
Maine
My story: Approx 2000hrs, L4740, she starts great when temp is above approx 45ish, but below that, very hard to start and it smokes a bit more at start (likely unburnt fuel, as it smells of diesel). I strongly suspect glow plug(s). Starts extremely hard when it is cooler out, but once started, or once engine is warm, no problem running/performing/ starting again.
I looked at a couple relays under dash and everything seemed good.
Ive never replaced glow plugs on this unit before but understand that I have to take off a manifold to access them.
My question: Do you also suspect glow plugs?
If so, any advice on replacing them on this tractor?
If not, whats ya guess?
Thanks,
Nick
3,987
I would also expect a problem with the glow plug circuit. But before I loaded up the "parts cannon", I would test the whole circuit.
The WSM should have the procedure for testing the system.
Hugo Habicht
G1900
Jun 24, 2024
863
1,191
Ireland
You can test the glow plugs individually: Glow plug testing D722
Different engine, but the method should be the same.
And yes, I think you are on the right track suspecting the glow plugs or glow plug control electronics from the symptoms you are describing.
Do you have a work shop manual? If not you can download it on link to kubotabooks.com
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,434
2,016
WestTn/NoMs
That's a good glow plug test. Also, check to make sure they're receiving power when they're supposed to.
