With winter upon us I was on the road today plowing some driveways. I tried to use the ATA for the first time. With the lever engaged and also auto throttle selected on the dash I pressed down on the peddle and the tractor moved and the rpms began to rise as it should then within a second or two the RPMS bottomed out even though the peddle was still pushed to the floor. Each time I’ve tried this as been the outcome no matter where I place the throttle lever to start. Has anyone else experienced this ? It appears the electronics are initially communicating but then it stops working almost immediately. Any advice ?
Normal if stall guard is on and/or tractor is overloaded.
Pushing the HST pedal to the floor calls for maximum speed, thus requiring the most power. Even if the ATA calls for increased throttle, the engine will not be able to increase RPM if overloaded.
The hydro pedal is not an accelerator pedal although the distinction is blurred a bit when ATA is on.
It is possible to make a HST+ tractor buck like a bronco if HST+ is in auto and the load is great enough that the engine cannot produce demand speed in High but can in Low. Such conditions cause the HST+ to continuously shift from High to Low and back to High creating a bucking effect.
SDT
