Hi All!!
My headlights on my L45 won't come on. When I flip the switch on the steering column the dash indicator light turns on as if to say they should be on. I pulled off a headlight and confirmed with a voltage meter that I don't have power (12v) running to the lights themselves. I then went to the fuse box and swapped my back work light fuse (30A) with the headlight fuse (30A). I confirmed that the headlights still did not work but the back work lights did. I then pulled both 30A fuses and using a voltage meter confirmed I had 12v on the back work lights but didn't have any voltage on the front headlights (at the fuse).
I further tested the headlight dash indicator to make sure the flashers worked which they did.
I can't seem to find a diagram that shows how power goes from the battery to the fuse box for the headlights. I suspect that is my problem but wanted to see if anyone else has had something similar happen to them.
Thanks for all the great info on this site!
