The BT1000A on my L45 refuses to swing left under power. It will swing right without issue and with power, but it refuses to go left. If I put the right stabilizer down and hold the swing control left, the backhoe will swing left from gravity but there is no hydraulic power. As I slowly move the control lever left I can hear the start of hydraulic flow, but it goes to silence as I move the lever left.
I swapped the lines from the swing to the boom and the boom had similar issues. It would power lift, but had no power down. The swing function worked fine with the boom control valve.
Any suggestions are greatly appreciated!
ac
ac
