Hi guys, I’ve got an L4400 and I’m in a bit of confusion here. I did search before so if there is a post on this, I apologize. Anyway, had a stick pop up and twist the fuel bowl mount...in turn this broke the nipples off the top for the line connections.
Purchased new fuel bowl assy, put it on and of course ran the battery down before I got it to crank. Hook up jumper cables, attempted to bleed the pump and then bled the injectors. Cranks right up, everything is tight... no leaks. But I noticed while using it the other day that it seemed to be blowing more black smoke than normal and also bogs down when it previously wouldn’t. Today, while on the trailer, I bled injectors again, mainly for the heck of it. (Ran it low of fuel last time I used it) Cranks right up, no issue with that-still excessive black smoke and now rattled on a few seconds more before shutting off after the key is turned. Changed air filters, no change in the way it’s acting. Haven’t had a chance to pull the disk to see if it’s still bogging but I’m going to assume it will with the excess of fuel. Lines are hooked up correctly also.
Any help would be much appreciated.
