L4400 fel not working
7,457
OK - we seem to have that much working. Run the power beyond hose into the oil filler and tie it up so it cannot flop out and spray oil everywhere. Leave the tank hose in the bucket
Now we are gking to test the lift function. Using the quick connects disconnect both bucket hoses from the loader valve leaving just the two boom hoses. Take a picture of those connections.
Start the tractor and move the joystick to raise the loader.
Does it go up?
Do you get oil out of the tank hose when it goes up?
Will it go down?
Do you get oil out of the tank line when it goes down?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,104
2,528
WestTn/NoMs
Sitting in the seat the power beyond shoukd be the port on the RIGHT side. That port is cutoff on your pucture but if you look at the area I highlighted in blue I think you will find a ID cast into that boss.
I thought 'we' determined that T embossed in the housing meant the hose running down was T and the one heading off the left edge of the picture has the PB plug and hose.
Edit: your test may indicate otherwise.
7,457
I thougtt thats what I just said.
I dont believe that valve requires a power beyond plug.
Edit. Let me take that last part back - there is a sleeve in that port :mad: Additional confirmation.
bsamot69
M9000, m9540, m6060, L4400, SVL 97-2
Jul 31, 2018
152
Grapeland, Texas
Does it go up?
Will it go down?
It did not go up. Oul came out of tank line into bucket. I pushed joystick to lower no action and oul came out into bucket
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,104
2,528
WestTn/NoMs
Assuming you still have the hoses hooked up like in post 106, push the joystick to the left and then the right. Which hose gets the flow? Do you hear the relief valve open when you push the stick to the side?
bsamot69
Jul 31, 2018
152
Grapeland, Texas
It does not feel like there is any flow when I move joystick
7,457
There is nothing going into bucket either if that means anything
How do you know any of thst?
The next think I want you to do is disconnect both of the two hoses going to the cylinders. Do that at the nearest pount to the couplers. Put them in a small can or bucket and test up/down again. That will tell us if the valve is sending fluid out to the cylinders.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
There is fluid shooting out.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Fluid is flowing
7,457
Fluid is shooting out of where and when?
Are both couplers still connected at valve?
Are both hoses still connected to the couplers?
When ypu move lever down fluid should come out of th we open end of one hose only.
When you move lever up fluid should come out of the other hose.
Is this the situation?
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Let me do it again, to verify . Be right back.
7,457
It's good pressure, too. Why is it not raising or lowering? Confusing and interesting.
Thats why we are going through the circuit inch by inch.
We now have verified outflow at both workports. Next up - the cylinders
Reconnect the ends on the two quick coupler hoses.
Go to the lift cylinder on the right frame and disconnect both hoses. Put them in your bucket and repeat the last test. You should get alternating flow as you move the lever from up to down. Watch yor fingers in case the loader decides to move.
If you get flow reconnect the hoses and go to the he left side cylinder and repeat that same test.
