Data sheetsMost unusual that all four cylinders go kaput at once.
I'm conflicted here. @TheOldHokie would tell you to replace them all. I'm the type that likes to know why and how, it carried over from my earliest days. So let's do this:
Measure one of each cylinder so we can shop. We need
* Cylinder diameter
* Rod diameter
* Length, center-to-center, when rod is completely extended
* Length, center-to-center, when rod is completely compressed
* Diameter of the connection pin on the rod end
* Diameter of the connection pin on the cap end
* Width of the rod end
* Width of the cap end
* Picture of each end
If you have a good hydraulic shop available, you could take them there and have them check them out. If they just need seals, you'll come out ahead replacing seals. But your symptoms suggest more serious problems, so I wouldn't have them do anything more. Have $300 for a new cylinder in the back of your mind.
Since you're about to spend some money, let's review. For
$1200 cylinders
$500 12 hoses & connectors
$300 joystick valve
$2000 total
you'd have new loader hydraulics. You might not need all of this right now, of course. But, before we start spending your money on hydraulics, are you reasonably sure that the structure of the loader is good? Is it square, do the pivot points move ok and without too much slop?
I have some pictures of the piston end/seals. I don't know what that chunky stuff is..it is hard as rock. The inside diameter of cylinder my micrometer can't reach so, I measured the spacer rings on each seal assembly. I'll send photo of cylinder inside, not great but it may be helpfulThat would indicate more than a seal failure. No, capping it now wouldn't add anything.
Repeat the steps in posts 168 and 171 on the other three cylinders and report back.
The iD for tilt cylinder is 1.890 inches
The rod end width of tilt cylinder is 2.845
The cap end width is. 2.120
The lift cylinder ID. 2.110
Rod end width. 2.871
Cap end width. 2.196.
Hope this helps
