L4310 HST Won't Start
gcw804
Kubota L4310HST, 6' box, 6' Land Pride Finish Mower
May 5, 2013
Mechanicsville, VA, USA
My 4310 won't start.
I turn the key and the glow plug lights up, then goes off like it should. I then turn the key to the start position and nothing happens.
The battery is relatively new and I took it to the Kubota dealer and they checked it and it's got plenty of cranking amps.
I'm pretty sure it's a interlock somewhere.
Any help would be appreciated.
TIA
Gary
2,561
There are several safety switches (seat, clutch,HST pedal, PTO lever).
Find the one that is not letting it start and fix it.
You can try to hold the key in the start position and move levers or pedals one at a time to see if it will start cranking. If that happens then that is probably the switch to repair or replace.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
531
216
CNY
There are only two safety switches for the start sequence. That is the clutch switch and the PTO switch. The PTO is disengaged correct? You are depressing the clutch fully correct? It has to be as far as it will go for it to start. Other than that it s the same stuff, ign. switch, relay, starter and associated wiring.\
gcw804
May 5, 2013
Thanks
gcw804
May 5, 2013
Thanks
