Hi all, new member here. I'm not new to tractors or mechanical repairs but I am new to having to work on my Kubota. It is a 2015 L4060HSTC with fairly low hours. I went to move some gravel the other day and the response from the pedal seemed really sluggish, almost like I had left the parking brake on. I checked and it wasn't that. Then, as I moved it a bit more to try and figure it out, I noticed when turning that it was like the rear wheels were not moving as freely as they should have been, causing steering to also be difficult.
I took the pressure washer to it last night to get it cleaned up before having a look at it today. I've been through the owners manual a bit, but it doesn't seem to cover the brakes in a whole lot of detail.
My thinking is, if I'm parked on an incline, put the range selector in Neutral and release the brakes, it should roll. It does not do this, so I'm thinking somehow the brakes are stuck. For now I'm going to trace out the linkage and see if I can find something obvious. Any suggestions?
