l3901 disc harrow
dterry302
12
Florida
Hi I just bought a Kubota 3901 about 6 months ago and I now need a new disc harrow. Will I be able to pull a 6.5 ft box frame disk about 800 lbs? What size do you guys use thanks Drew
6,985
HP requirements can vary, it depends on soil conditions. ;)
Weight wise you should be good. :)
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
319
26
23
Mobile, AL
I have an L3800 which is about the same size tractor. My manual show max weight for a disk is 650 lbs.
JasonW
306
145
Al
I pull a 5.5 ft box frame disc with my L3800. It weighs about 850lbs, 90% of the time I'm in medium range(HST trans) other 10% it's in low range.
EDIT
I will also add I don't run out of power pulling it but lose traction. This is with R1 tires, in 4wd, loaded rears, and with the factory loader.
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
437
41
Red Springs, NC
I pull one with 20-18" blades it is 6'10" the way the blades are set. Med range with R 4 tires and it does great. Our soil is fairly sandy. No red clay in my part of the world.
