L3800 died
RichardSATX
B2400HD, RTV1140, L3800
Apr 15, 2011
22
San Antonio, Texas
Just started using my new L3800 this morning. It began losing RPM until it died, over and over. I finally got it back off the road so I can wait for service to show up. 2014 with 2 hours on it. Front loader and backhoe. I know service is coming out, but does anyone know anything to check while I'm waiting? The fuel bowl is full with no water. The last 15 second start up that I got, it blew a bit of white smoke out the exhaust.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
10
East Hampton, CT
New machine....assuming it has oil and coolant in it, I would guess fuel related. Even without visible water in the fuel you could have contamination. Also I have seen people accidentally put GAS in a diesel, will cause same symptoms. In one case in CT the GAS STATION had gotten a load of gas put into the diesel tank by accident, it wasn't even the people's fault.
RichardSATX
Apr 15, 2011
22
San Antonio, Texas
The tech said he thought it was air in the line. I used it for 2 hours solid with no stalling. But now a hose on the front loader is leaking. I'm pretty disappointed. I've already cancelled my work this weekend because of this. I've got some PO'd customers. I'm wondering if I made a big ole mistake buying this thing.
6,419
Did you run it low on fuel?
Is the leak on a fitting?
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
Full of fuel, and the leak was where the rubber hose went into the metal sleeve at a fitting.
We had several issues just like this on a brand new JLG machine at work. This was dropped directly to us with no run time other than production and it had some bad crimps resulting in hydraulic leaks.
That is what warranty is for so it should be a small bump in a smooth road ahead.
Good luck with the orange.
Jan 30, 2014
132
Central NY
Don't panic . . It's probably something really simple and easily fixed. If a new system (be it mechanical or electronic) is gonna fail . . it will do so in the first 1% of it's life cycle . . get past this and you have a 10K hr machine if you do your part regarding regular scheduled service . . .
Smarter people than me here will get you back up and running in no time . .
Bluegill
Jan 11, 2012
1,560
Success Missouri
You have a Very Good machine! But with a minor problem right out of the shoot.
Get it fixed and enjoy.
09Ram
09 Ram 2500, Grand L3830, GST, 6 ft Brushhog, 6 ft Box Blade, 8 ft Disk, Auger
Jun 8, 2013
45
Tahlequah, Ok
Did he get it fixed?
RichardSATX
Apr 15, 2011
22
San Antonio, Texas
Ewald Tractor where I bought it sent a tech who replaced the hose, and also replaced the same one on the other side to make sure there was no problem. Great service, now I'm about to get back to work with it and see how it does.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
What was the final outcome on it not running. What did the tech find and how was it fixed, now that it is running?
FLHollowPoint
L3800 HST 4WD, 72" finish mower, 72" rake, 5' Bush hog, 5' box blade, hay spear
Feb 16, 2014
45
Weirsdale, Florida, USA
I also have a new L3800, only 6 hours on it and found a hydraulic leak. Service came by today and took care of it, o ring not seated correctly on the hydro block next to the filter. not a major problem. The service tech explained that its good to check all the hose fittings after each use on a new tractor. They may get, lets say sprung during install and can back off with use until they get more flexible. Hope I am making since. It made since to me. Other than the leak the tractor has been perfect during my first 2 projects.
buckaroo52
Kubota L 3800 DT
Jun 5, 2013
102
Molalla, Oregon
Very hard to imagine your dealership had something so noticeable like a hydraulic leak in plain sight get past them? I would guess your dealer installed your loader on the new tractor, as they don't come with them but as an option. Good luck.
Bluegill
Jan 11, 2012
1,560
Success Missouri
I doubt it was leaking when the dealer had it. Probably started after some use.
