L3710 Value?
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
I have an L3710 HST. It has a loader and two rear remotes. It has about 1250 hours. No cab. I don't know if they ever came with cabs. It's 4-wheel drive with a mid PTO.
I got it in 2017 from the first owner. It has had very little done to it. I kept up with oil and grease, but it is overdue for its 1200-hour hydraulic fluid change.
Everything works. It needs a new blinker level and decals.
I added a skid steer adaptor up front, so I modified the bucket to accept it. I also have a set of Pat's Easy Hitches on it.
It has turf tires in back, filled, and skid steer tires up front.
I had to have the steering cylinder rebuilt. In the process, I broke the front engine cover, but it has been replaced.
The spools for the loader got rusty. I replaced one, and I have the parts for the other, so it will be fixed, too.
It spent nearly all of its life indoors at night, but I put it outside for a year or two, so there is some fading. It has normal wear. No rust to speak of.
What's a tractor like this worth?
I see someone advertising a bigger TYM at a price I like, so I would like to know what I can get for this one.
JimmyJazz
1,270
805
Pittsburgh, Pa
post some pictures if you are able and state where its located maybe someone on this forum would be interested.
PaulL
2,647
1,628
NZ
I didn't think L series machines (other than grand-L) had a mid PTO?
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
That $16K guess is right in the range Grok suggested. Thanks.
9,584
Is that not a grand-L? I thought the 50 and 60 series were grand L.
The only thing grand about my L is the price i paid for it, 2 grand many a year ago.
The 30's 40's and the 60's are the grands.
The 50's the 00's the 10's, I think all had Mid PTO's as standard equipment.
PaulL
2,647
1,628
NZ
Aha. That's what I get for pattern matching. 30, 40, 60 all grand. 50....not. I guess that's why they didn't reuse the number.
9,584
Here's another head scratcher for you, there was 4 runs of the L50 series too.
2 runs of the smaller L's, and 2 runs of the larger L's.
