l3600-l3710
KJD455
l2550, b1750,l1501, JD455
Jan 9, 2014
12
Europe
hello,
I can buy a 2002 kubota l3600. I was looking on tractordata for the model kubota l3600, these models were built from 1994 to 1999. But this one is from 2002, and the only tractor what looks like the l3600 and from 2002, was the l3710. So the question is: is there any difference between the (European?)l3600- l3710.
Because the l3600 has an orginal kubota cab, and its missing his right door. The only doors I found were from a l3710.
The tractor has also a HST, tractordata says it wasn't an option on a l3600.
the tractor has about 4000 hrs. Is this much for an HST? It's te first HST for me in a kubota tractor..
I'm an european, so sorry for any grammatic mistakes.
Thank you!:D
2,600
hello,
Thank you!:D
Welcome!
as for grammatical mistakes.......dont worry 'bout that! WE have our own language - it is called ORANGE!:D:)
Now - lets get back to the tractor:) - it is clearly marked on the bonnet? L3600? Or is someone telling you that? And the year? How do you know it is a '02 model? Again - most people never know the year made unless they bought it new, or have done a lot of research by the few small changes that happened through the years.
Looking at tractordata.com - you are right- the HST did NOT come on the L3600 but did on the L3710....I wonder if a bonnet was switched?
can you send a picture? Easy to do too!
And 4000 hours, that tractor is up there - and if taken care of, could be a fine tractor. But it could be worn out too! , Does it starts and not smoke after the warm up? What is the "dealer" asking for it?
As for as Euro vs North Amer models - someone else might be able to chime in on if there were differences.
rbargeron
Jul 6, 2015
1,171
238
western ma
An L3600 could have GST tranmission, not HST. The GST has a regular clutch and gearbox but shifting is automated.
4000 hours is a lot of use - think of a pickup with 200,000 miles on it. Maintenance and type of use are everything. Could be very worn in areas expensive to fix - get an experienced tractor person to look at it with you?
Cabs are pretty different - quick visual clue is Lxx00 cab front glass is flat 3-pc - Lxx10 front glass is curved 1-pc. Kubota website parts lists would show if any parts are common to both.
KJD455
Jan 9, 2014
12
Europe
thanks!
the owner is pretty sure thats a l3600. The engine is broke so i can't see it running.. But the owner says the maintenance was good till it broke down. (engine was frozen during winter). Since then was the tractor set in the barn.
I can hardly see any kinds of rust too.
Price is about 5000 USD with cab and loader.
