L3560DT-LE, 296hrs. Suddenly won’t go f/r
JonathanP
Kubota
Jul 22, 2021
22
10
Pinckney, MI
Have a L3560DT-LE, with 296 hours on it. Was moving some pallets without any issues. Went to change from forks to bucket, once I attached the bucket on the tractor, it suddenly wouldn’t move. I went through all the gears in both HIGH and LOW, but only would crawl in LOW 1st gear. I parked it, shut it off, looked it over, saw nothing leaking, checked hydraulic level which was fine. Fired it back up, and now won't go forward or reverse in any direction, no matter high or low, or what gear I put it in.
I left it alone for about 10 mins. Went outside, fired it up, put loader through range of motion, no issues. Checked the PTO and it ran fine. If I adjust the rpms all the way up, it will creep forward, but only in LOW 1st gear.
