bxchapm
2014 L3540HST/LA514; Toro Mx5050; King Cutter Box Blade;Dirt bucket;snow bucket
Hey everyone. New Tractor owner (1 yr) and pretty new subscriber here. I have reviewed many threads for various tips/tricks and appreciate all the knowledge and helpfulness here. Soliciting a bit of help here. Lost the loader down function about a week and a half ago. Tilt, Curl and up functions work. I have replaced two QD couplers (including one male side on the lowering line) that seemed to have frozen nipples. All QDs are connected. I did have to release pressure on the lowering line to disconnect the coupler. Swapped lines and that did not help. I then removed the detent plug, cleaned and replaced. No luck. I did have ability to lower, raise, tilt and curl (at one point) without the cover on the linkage. I then replaced the detent cover and lost lowering function. I could not repeat the ability to lower with it off again. I checked the joystick and linkage there and do not see anything loose or missing. The joystick acts like it is stuck in float position and does not appear to engage and feels loose when moving to lower position. I do have the Detent Kit Plug coming but am struggling to see how to remove the Valve assembly in order to check the linkage going from the detent to the underbody section connecting the joystick. Sorry for such a long post but I see putting out as much info as possible can lead to a quicker solution. Any suggestion or help is greatly appreciated.
