L35 hydro fluid in oil pan
jasrking
IN
Topped of hydo fluid 2 weeks ago...ran tractor for couple hours since...been having problems with it loss of power and not having all gears...checked hydro fluid and it was down 2 gallons...checked the oil dipstick before starting it up and low and behold it was overflowing..it appears a lot of that hydro fluid went straight to the pan...cause?? Simple fix or shop fix? Cost? Will this also be the cause for loss of power and gears?
thanks!
rentthis
1,010
25
summerville,sc
Sounds like the seal between the hydraulic pump and the injection pump. In most cases, that's the only route between the hydraulics and the oil pan. It should be fairly easy and inexpensive to repair yourself. A workshop manual might show the repair. You can find a parts breakdown in Kubota's online parts system. It's possible for losing all that fluid to cause your transmission problems.
