L345DT timing cover oil leak
Sledhead
L345DT
Dec 15, 2022
WV
My tractor is leaking oil from under alternator mounting plate on timing cover. I removed plate and was full of oil in cavity under plate but looks to be no oil should ever get into cavity to start with. Anyone have this problem before, doesn’t look to have any cracks in timing cover
6,607
Either crack in case or something is pushing oil don to it.
Where is the valve cover breather house going?
rbargeron
Jul 6, 2015
1,171
238
western ma
My first L345DT had an oil leak I thought was at the front of the head. I replaced the head gasket but the leak persisted. Along the top edge of the front gear case its gasket to the block is very narrow. Oil was getting out through there. Rather than take off the cover I cleaned the area and put a bead of sealant in that corner - where the head, block and front cover all come together. That cured my leak, and might be worth checking out on yours? Take care, Dick B.
