I bought the L345 tractor (used) this fall and only used it once to bush hog 3 acres. I checked all the fluids after use and all was fine.
I am working a separate problem with the PTO H/L engage grinding a little too much and have to start the tractor up with the PTO engaged. I recently discovered this tractor had a suction filter on the hydraulics in addition to the circulating filter. So that was going to be my winter project, changing the trans fluid and cleaning the two filters in the system after the first of the year.
When I checked the trans fluid after using the tractor last, it was very clear and clean. Just this past week I was over and checked all the fluids and noticed when I checked the trans fluid, it was not the clear it was last time but was yellowish and milky. We do not get very cold here in Louisiana and the tractor was stored in a dry environment.
I know the oil will need to be changed with the filter maintenance, but is it normal for a tractor used not often to have what appears to be moisture show up being stored in a dry barn after its last use? Time since last use was about 2 months.
Thanks for any help.
JimDD
JimDD
