Hello all, I could use some help here. I did not push the clutch in while enaging my PTO drive and now I believe I stripped the engagement gear. So I'm seeking information before I go out and purchase a factory service manual. With no load on the PTO shaft, it will engage even though I hear a rattling noise when I using engagement lever. If I attempt to attach the PTO to a bush hog or any other employment then engage the PTO, you can hear the rattling and grinding of gears. It will not work with a load on it.
This is my first step in figuring out what I've busted and how to fix it.
Thanks,
Aaron
Thanks,
Aaron
