2007 L3400 430hrs today all of a sudden the tach quit working. Upon startup it just barely moves but doesnt even get up into the markings on the readout. I disconnected the engine end of cable, appears to be fine. Cranked engine while disconnected and looked down into the hole, the mechanism is spinning. Connected to a cordless drill, it did register on the dial, but not much, only a few hundred rpms (stands to reason the drill wont turn as fast as engine). Disconnected the instrument, appears fine. Started engine while disconnected, cable spins. Reconnected, started engine, still nothing. So everything appears to be working, but no read out on the dial. Could the cable still be damaged/broken and have the indications i mentioned here? Seems to reason if it was broken then it would be broken, but i dunno. Any other ideas on what it could be? Cant be too terribly complicated. Or i wouldnt think so.
