L3400 not starting, low voltage
Moab
L3400
Apr 9, 2012
Moab, UT USA
L3400 not starting. I checked: battery, main fuses, secondary fuses. At the secondary fuse box there is only 9.56V? Checked the clutch and seat safety switches, also 9.56V?
Any thoughts?
Thanks
Stumpy
L175
Dec 1, 2011
848
NE Ohio
12+ volts at the battery? That's a sign of an bad connection somewhere. Probably whatever wire supplies power to the secondary fuze box. I'd trace it just to be sure. Find the wire that has full voltage on one side and low on the other and then clean the terminals of that wire. If it's still bad replace the wire.
