L3400 LST Shut off and wont start
Copen
L3400 HST
Aug 21, 2016
Winchester, Va.
L3400 HST Shut off and wont start
This rascal was idling fine, then a little rough and finally just died and wouldn't restart. It acted exactly like it ran out of gas. It cranked over strong till the battery got weak. Changed the fuel filter. Didn't help. Any suggestions? Keep in mind it didn't shut off quick like turning the switch off, but slowly as if it was fuel starved. Just curious, how many fuel solenoids does this engine have?
Thanks, Bill
2,551
Re: L3400 HST Shut off and wont start
charge your battery - crack the bleeder screw and or injector, and see IF there is fuel coming from the tank. IF fuel, then should start, no fuel, backtrack.
could be fuel algae - restriction in tank, cap restriction...........
5,580
Hey, Bill, maybe this is your problem, "acted exactly like it ran out of gas."
If you put too much GAS in a diesel engine it will eventually quit running!
Copen
L3400 HST
Aug 21, 2016
Winchester, Va.
The dealer where I got my fuel filter sold me some Star-Tron Enzyme fuel treatment stating that would in all likelyhood solve the problem of algae in the poly tank. No guarantee. Best to crack the lines at the injectors or the injector pump? I would think the injectors. So, does this critter have 1 or 2 solenoids for fuel supply? Do you know if there are factory repair manuals available. The trouble I'm having is locating and identifing the different componants. Thank you.
6,389
There is not a free or cheap safe download available for that model.
But you can buy the WSM here:
http://www.colemanequip.com/parts/KubotaParts/97897-13190/277
First check fuel going to the injection pump, then crack injector lines at the injector to check for fuel there.
I've used Startron for years, works perfectly! ;)
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
358
89
Canton, MS
Got'er goin??? Without telling what got'er going it didn't happen !
