I have an issue with my 2010 L3400 when starting. If you turn the key to start from the off position, it will start and immediately die. If you do not turn the key completely off and try to start it will not start and solenoid will not click. Starts and dies anytime you start from the off position. When key is turned on, you hear a click from the solenoid followed by a second click and no start. Only starts if you go immediately from stop to start position, then dies. I'm not showing 12 v power on either of the two leads but my test leads may not be engaging far enough. Since it clicks, I assume I'm getting some power to pull the coil in. Can someone enlighten me on what's happening here????
