L3400 Fuel gauge on full, tank on empty
kennylee
L3400, L185
Sep 28, 2009
crestwood mo
I broke the plastic fuel filter housing (bad location for plastic parts) and had to replaced it, and the fuel gauge does not work. any suggestions?
Ob1kubota
M9540DT
Jul 26, 2009
316
Birmingham, AL
Heres a quick check for the condition of the resistor ( Pot) in the float gauge assembly. Follow the lead up from the tank and pull the pin connector a part at the first terminal and put your ohmmeter red lead to the pin and the black to a good known chassis ground and move the float up and down in the tank with a coat hanger and see if the resistance changes. If no change you need a fuel tank gauge. I know what you mean about those L series and that plastic filter housing ( sucks) but that 3400 is about the best compact out there for the price. Look at a Deere and you will forget all about that plastic filter housing..... man :eek: does Deere think a lot of their compacts. :rolleyes:
