L3400 change hydraulic pump inlet hose
nhinze
BX2200, LA211, L3400
Apr 6, 2010
10
Central VA
I have a hydraulic oil leak on my L3400 that I tracked to a cracked hydraulic pump inlet hose.
This part:
https://www.messicks.com/part/tc220-33332/assy-hose-inlet
It seems fairly straightforward to switch out as it is only held up by clamps and easily accessible.
However, how much hydraulic oil will I lose? What's the best way to minimize hydraulic oil loss? Can I park the tractor uphill/downhill a bit? Or with the ride side up? Would that help?
whitetiger
Nov 20, 2011
3,074
1,518
Kansas City, KS
This part:
Setting on level ground, you will loose a cup or less of hydraulic oil.
5,405
2,099
TC220-33332 I think. The original part number is NLA, superceded to TC402-33332 (I think that's the right number--going off of memory). It is a different material that isn't as likely to crack. There was a bulletin at one point.
