L3301 PO606 Code
Tom Gzz
L3301 with loader, scraper, tiller, 5' bush hogger
Apr 28, 2019
Greenwood, VA
I have 25 glorius hours on my 3301 and survived my first DPF about 8 hours ago. What does PO606 code mean? The tractor seems to run fine but the code flashes with the hours. No other indicators are presently lit. Many thanks in advance.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum Tom. :)
As you can see, you came to the right place to get answers.
200mph
Mar 3, 2017
1,228
65
PA
Seems like a trip to the dealer will be in your future.
Let us know how they fix it.
5,501
2,207
Usually a low voltage issue, but not always
could be a ton of things
corroded ecu connector, wiring damage, dead battery, loose connections, etc
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Clear it and see if it stays away, It probably will!
