I have a very young L3301HST with 19 hours on the clock. A couple of minor issues have developed with the loader valve, and I want to take a look at it myself before involving the dealer:
I don't know if I can do anything about the float detent without digging deeper into the valve body than I would like to, but I would at least like to take a look at the lockout. I assume that the lockout function is external to the valve body. Maybe I'll get lucky and discover that whatever mechanical misalignment is affecting the lockout is also preventing the valve poppet from being moved far enough to fully engage the detent.
So that brings up the question that brought me here: How do I remove the plastic housing which covers the top of the valve assembly? I have a hunch that I will need to remove some or all of the bolts which I can see on the bottom of the metal plate under the valve assembly, in order to lift the valve up and expose whatever fasteners hold the plastic cover on. I don't have a service manual yet, so I'm feeling cautious about blindly digging into the loader valve assembly without a map.
- The mechanical lockout lever on top of the loader valve can no longer slide far enough towards the right to be engaged. It worked when I got the tractor. I haven't felt any real need to use the lockout, but something has clearly shifted out of its proper position.
- The float detent is no longer strong enough to hold the valve lever in float position. I can still float the bucket by holding the level upwards, but it won't stay there.
