L3301 HST and at times the streering is very heavy(power steering)
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
45
29
duluth mn
It is not constant, sometimes it"s fine and then it"s not, RPMs at idle or 2500 make very little diference when it happens.
Hydro oil is full and everything else works fine.
Thanks!
Don
9,171
When was the last time you did a fluid and filter change?
How many hours on on it?
5,649
Thanks!
Don
How is the 3pt? Do you have a loader on the tractor and if so how is it working,?
DONLI
Jul 28, 2025
45
29
duluth mn
Loader and 3pt work fine even when steering is hard!
Just bought this tractor in mid June has 500hrs, do not know when fluids and filters wheree changed.
Been wanting to do it all but have not had time, was thinking to do them in the spring when I can bring it out and work on it in the Sunshine. so not like being on the ground when it is cold.
I am not a spring chicken anymore and the cold gets to me fast.
Thank you.
Don
5,649
Been wanting to do it all but have not had time, was thinking to do them in 9th the spring when I can bring it out and work on it in the Sunshine. so not like being on the ground when it is cold.
Thank you.
Don
The PS and implement pumpd share a common filter and supply so that suggests its not a suction side problem.
9,171
I would start with a fluid and both filters changed as anything else gets a lot more complicated and pricey.
mdhughes
L3901DT
Dec 10, 2014
1,353
1,106
Ste Geneveive county, MO
Thanks!
Don
Does this happen on the same ground? I have a L3901DT and there are times in soft/muddy ground when it seems like the power-steering isn't working at all, but the front tires are in really soft or muddy ground.
DONLI
Jul 28, 2025
45
29
duluth mn
It does not matter on what ground it is on, what I can not say is if it is only when in 4 wheel drive, I will have to ck that next time I have it out.
I do know that it does this wheather there is a load on the front or not.
Right now I am doing some lighting wiring so not going to start it up with all these wires hanging out.
Thanks !
Don
5,649
Thanks !
Don
The workshop manual is your friend.
