My 3301DT began dying suddenly a few months ago - about 220 hrs, & 4 yrs old.. Initially I cleaned out the water trap and changed the fuel filter but with subsequent failures began to notice it would happen after a couple hours of use. It takes about 1 hour in the heat of summer. Other red herrings were chased but turned out not to be consistent, like happening when fuel got down to 1/4 tank.
When it dies it's very sudden without sputtering or warning, like it's lost electrical. At one point I thought I had it figured out after holding the seat switch closed with a zip tie but yesterday it did it again. There are no error codes and the fuel pump runs when attempting to restart. No difference if I vent the fuel tank.
I'm beginning to think the electronics are overheating - some hairline crack in a component or solder joint that expands with heat. Coolant temperature is normal. It always restarts after a couple of hours of cool down.
Has anyone else had this problem or had this problem fixed by the dealer?
