L3240 HST “No Start “
RockinJ
Kubota L3240 Grand HST
Sep 29, 2017
Shawnee Oklahoma
I’ve message today on my tractor problem not starting with no response wondering if I posted wrong or something no responses ! Surly not the first with electric pto reading engaged on dash, but is not Switch tested good so won’t start could it be my pto solenoid ?? That’s the only connection I haven’t test because of being down in the field. Jump started to load on trailer , $150 hr to work on tractor , Please Help !!!! Tim n Oklahoma
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Generally a tractor won't CRANK unless the safety switches - PTO (rear and center if it has them), are not selected or engaged, and the neutral selecter switch, clutch switch, cruise control, need to be in correct position, meaning in neutral, and clutch depressed, cruise control off, both PTO off.
You say, "Jump started", so does this mean your battery is failing, or you jumped the circuit at the starter to bypass the safety switches?
RockinJ
Sep 29, 2017
Shawnee Oklahoma
Yes bi passed the only way we could start it to rise front loader . All the switches showed goo when testing. Like I said in my first of two post the only one would be pto solenoid, How and where is it ? Cruise Grear all in neutral, both switches unseat good , PTO knob not lever good, When your in seat clutch in in neutral turn key hst in neutral get a warning beep “ PTO Clutch Neutral “ @dash , pto is off so tractor thinks it’s in gear pto
