L3200 front end
bwssr
l3200, FEL and Box blade...more to come
Feb 29, 2012
49
Houston, Texas
My L3200...2011 4x4 gears front end looks odd...1 tire seems to be tilted out at the top...is this normal?..I can't see any way it can be adjusted...wish i had a pic..
hodge
Nov 19, 2010
2,954
517
Love, VA
Both tires tilt out at the top, it's normal. You need to look closer.
And make sure that when you are looking at it, the axle is square to the tractor- one side higher than the other will change how it looks...
You could also park the tractor on a hard surface, and use a framing square to check how much it leans out. Then, measure the other side. You could also run to your dealership with your framing square and tape measure, and check a new tractor. Then, you will know whether you have a problem, or if it's normal.
bwssr
Feb 29, 2012
49
Houston, Texas
Check from several view points this weekend.. and yes both sides are equal, thanks!
