L3130 won't start some lights
Tgweaver14543
Kubota L3130 ferris pro cut 61" 2003 chevy silverado 2500 HD
May 3, 2017
Rush, ny
So we have a L3130 model LA513 we use it every day. Went to start it the other day for chores and it won't start. When you depress the clutch and turn on the key the instrument panel lights up but not all the way. Like it turns yellow but non of the information comes on. It doesn't click when when attempting to start. I don't know what to do the dealer is so expensive. Wondering if anyone else has had this problem before?
Sent from my SAMSUNG-SM-G890A using Tapatalk
rentthis
1,007
24
38
summerville,sc
clean your battery terminals as well as where the ground cable connects to the frame. it sounds like you might have a bad ground.
Tgweaver14543
May 3, 2017
Rush, ny
That's what I thought I'd there any other grounds we did the one from the battery to the frame didn't know if there were more grounds
rentthis
1,007
24
38
summerville,sc
you can connect a jumper cable from the neg battery post to a clean spot on the engine. If the problem goes away, suspect a bad battery ground cable. Your battery might be charged but could still be the problem. Batteries cause some strange things.
Tgweaver14543
May 3, 2017
Rush, ny
Oh okay indo that with my gator good idea
Tgweaver14543
May 3, 2017
Rush, ny
Yup it must be the battery did that with a jumper box was able to get it to turn over....now how do u get the battery outta there so tight
