C Cvande New member Equipment L3130 Jun 7, 2018 1 0 0 Sumter,SC Jun 7, 2018 #1 Starts up just fine. As soon as I engage PTO or let off clutch to go forward or reverse the engine shuts down. Any suggestions? Last edited: Jun 7, 2018
B Brick Axelrod Member Equipment L5460, BH92, RCR1872, FDR2572.RTVX1100c Apr 12, 2018 135 9 18 South Carolina Jun 7, 2018 #2 More info would help, is it out of fuel? What were you doing? Any trouble lights? Any weird noises? Does it have oil?
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 7,343 2,725 113 Austin, Texas Jun 7, 2018 #3 Check safety switch under seat. It may not know anyone is sitting in the seat so won’t operate Assuming your tractor is fairly new and has safety switches Sent from my iPad using Tapatalk
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 35,172 10,385 113 Sandpoint, ID Jun 8, 2018 #4 Yep seat switch (most likely), fuse for OPC, bad OPC, bad connection or wiring.
