Hello everyone,
I have an L3130 with the manual transmissions (not shuttle shift). The last few times I've used the tractor I've found it almost impossible to shift in and out of 4wd. I had to give up and then try 15 minutes later...sometimes it worked then, sometimes I waited another 15 minutes. Obviously the time in between doesn't matter but I fiddled with the thing driving forward/backwards for at least 5 minutes each time without success. Everything else seems to work fine....no grinding noises ever. Once in or out of 4wd it works as expected. Any thoughts/help would be appreciated.
-Justin
-Justin
