This tractor has about 1900 hours and starts and runs fine. Fuel filter recently replaced and fuel regularly conditioned with Diesel 911. My fuel is pumped into the tractor through a filter and water separator on the fuel barrel. However, the engine randomly cuts out. When I turn the ignition to restart as long as I hearing the 'click' when the switch engages the engine starts fine and purrs like a kitten. If there is no 'click' sound it cranks and won't start. Often when it stalls I will hear the 'clicking' sound. Tractor is not low on fuel when this happens. It seems like an electrical issue that cuts off the fuel supply. Not sure if it's a bad ignition switch or something else.........thoughts??????
