L3130 hydraulic hose
Tgweaver14543
Kubota L3130 ferris pro cut 61" 2003 chevy silverado 2500 HD
May 3, 2017
Rush, ny
Looking for a bucket hose for my l3130hst. It's the short hose that cause the bucket to tilt up or dump out. I found a website that you send it in and they rebuild it but I'm not sure I wanna be with out my work horse that long. Ideas?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Grouse Feathers
Feb 16, 2015
1,022
10
Lovells, Mi
Re: L3130 hydrolic hose
Check the auto parts stores or hydraulic shops if any in your area. They can probably make a new hose to match while you wait.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
That would be the quickest if you have a place close by that you can do that. You can also check out discounthydraulichose.com. They have a guide that will help you determine the thread size and type on your hose, and how to measure for a new hose, then you can order the size you need with the appropriate fittings.
5,689
If you don't have someone like an O'reilly Automotive nearby, look up a construction company and ask them were they get their hyd. hose. They may very well make up their own. See if they would make one for you. Or, find out where they get theirs.
200mph
Mar 3, 2017
1,228
61
PA
Did you check with your local Kubota dealer? I think the ones you need are under $25.
I've bought some hoses from the dealer and had a few made up in the past. Really didn't see much difference in price one way or the other.
