L3010HST no start
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
363
Homer City, Pa.
Battery was 8 years old so I replaced it with a new one, still no start. checked all wires, jumped starter and solenoid would not engage,, new starter, still no start? Fuses are good, key switch reads good, bypassed clutch safety switch, ordered new starter relay, what am I missing???
ruger1980
L4310 w/La682, L225
Oct 25, 2020
408
147
CNY
You need to be more detailed with your complaint. Does it crank at all? Slow Crank? Crank fine but no start?
You have replaced a lot pf parts but what diagnostics have you performed?
Big Kahuna
Dec 23, 2011
363
Homer City, Pa.
No crank at all I am terrible with electrical and replaced what I thought was needed, I am wrong, bit complex machine for me to understand
ruger1980
L4310 w/La682, L225
Oct 25, 2020
408
147
CNY
This series of machines is about as simple as they get. You really need to learn how to use a test light and or multimeter. This will tell you where you have voltage present and where it is not in the circuit when trying to actuate the starter.
1,441
What happens when you turn the key to the run position? What happens when you turn the key to the start position?
Do any lights on the dash come on or go out? Are there any noises at all?
Since you replaced the battery did you also replace the cables, or at least clean the cable ends and whatever they connect to at both ends?
Since you disconnected the battery, did you miss replacing any other wires that may be connected to the battery cable terminals?
6,594
How exactly did you jump the starter?
Big Kahuna
Dec 23, 2011
363
Homer City, Pa.
Turn key on, glow plugs cycle light goes out turn to start postion lights on dash dim like it's sending power to starter, have test light hooked up at black exciter wire on starter no power there? Clutch switch by passed for now with a jumper. Key switch cleaned and tested with light, checks out.
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
97
32
Fort Calhoun, NE, USA
If the treadle pedal is not in neutral the key won't engage the starter. Rock the pedal back and forth a few times to loosen it up and then see if it will start. May need to lube the pedal.
StephenR
37
20
Kentucky
Check ALL of your safety switches, seat switch, brake switch etc... to make sure you have the proper connections, and they are good. It sounds like you have something that is not making a good connection to carry the power to the starter.
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
219
155
NW WI
I had a similar issue on my L3010. Turns out that where the battery cable attaches to the starter was nearly broken off. I put on a new battery cable, and problem solved. It tool a few tries to tighten it down to the starter (and not too tight),
My ground wire connection was okay, but you should check yours.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
408
147
CNY
Here is the start schematic and the start checking section. This should get you somewhere.
The Safety switches are on the ground side of the start relay. You should only have the clutch switch and the PTO switch on this tractor. The start relay is under the dash so you will have to get to that to test it.
Do you have a voltmeter to check battery voltage?
Big Kahuna
Dec 23, 2011
363
Homer City, Pa.
Volt meter came today, brake safety switch working, pto bypassed for now, battery cables replaced 4 years ago, I do have issues with the fuse holder, but don't think that's my problem, but could be wrong, going get back into soon. oh no seat switch on it.
Big Kahuna
Dec 23, 2011
363
Homer City, Pa.
THANK YOU FOR THE DIAGRAMS.....WAY BETTER THAN WHAT I HAVE(y)
airbiscuit
Mar 18, 2021
219
155
NW WI
Connect a jumper cable from the positive terminal of the battery to the stud where it connects to the starter. Connect another jumper cable from the negative terminal of the battery to a good ground.
That should rule out a bad battery or bad starter.
Big Kahuna
Dec 23, 2011
363
Homer City, Pa.
Did that, that's how I ended up with a new starter
N3BP
Sep 20, 2016
473
201
Lebanon, PA
Jumping the starter with jumper cables doesn't kill a starter unless the starter was bad previously or the procedure was done incorrectly. It's the only method to determine if your issue lies on the high current starter side of the system, or low current trigger side of the starter solenoid.
This issue comes up several times a year on here with grand L00/L10 series and it's normally due to poor cable conditions or connection points between the battery and frame, or battery and starter. A volt meter or test light can give you a false impression of your cable or connection conditions. You can have enough connection left for the meter to tell you that you have 12V. When you go to fire the machine, the 100+ amp demand will drop that voltage down to nothing. That's why it's important to start diagnostics with a known good battery and set of jumper cables.
The first connection that seems to go bad on this generation of machine is the under the battery tray where the negative lead connects to the frame. It only takes one leaking battery to doom this connection point. Good luck with your diagnostics.
