L3010 lost forward
jeb
L3010HST
Feb 1, 2015
ohio
I have a 3010 HST changed oil and filters in diff 3 weeks ago and filled with sudt2, drove it around and parked it till snowed today. Now I have no forward but reverse works fine, no abnormal noises and no change in engine noise when trying to move, checked all linkages and everything seems to be moving with pedal and oil level is good.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Hey Jeb, welcome to the forum. What part of Ohio are you in? I have a daughter in Columbus.
jeb
L3010HST
Feb 1, 2015
ohio
Northwest corner, been reading the site for a while but couldn't find any answer this type of issue
mickeyd
Mar 21, 2014
1,192
Guin, AL
So are you up around Toledo or out around Bryan?
1,418
I do not have a HST so can't offer much help.
I know that the cold will effect how the hydraulics work and there is probably a lot more fluid required in forward compared to reverse.
To help others diagnose the problem it might help to provide more information-
How cold was it when you had the problem?
How long did you allow the tractor to warm up prior to trying to move it?
Does it get any better the warmer it got or was it the same for a long period of time?
6,436
The HST's are fairly complicated and repair would be based on your skill level.
If it's not a linkage issue, then you have a couple options:
1: get the WSM for your tractor and it will walk you through troubleshooting and testing the HST system.
2: Take it to a mechanic/dealer and let them trouble shot it and fix it.
WSM: P/N 97897-12192 $94.61
http://www.colemanequip.com/Parts_Detail.asp?partID=19472
jeb
L3010HST
Feb 1, 2015
ohio
The temp was around 15-20, I let the tractor run for about hour and a half with no change. Thought that maybe it was froze up so I put a tarp around the tractor and blew heat on it, still no change, jacked up a rear wheel to see if I could get any forward movement and still no forward. Reverse works like normal just no forward, I ordered a WSM earlier in the week just waiting on it to arrive to do some reading.
jeb
L3010HST
Feb 1, 2015
ohio
Hate to bring up and old post but wanted to update with an answer, been busy with other things and finally got around to working on tractor couple weeks ago sorry for the delay, found feed-back lever in regulator had broke an ear off and would only engage in reverse. Dealer said I had to get a complete regulator to get that part, wanted $2000 for it, had a machine shop make one and installed, everything seems to be working correct now.
