My L2900 is smoking from the down tube not the exhaust. It also has a fairly noticeable knock when cold. Smoke seems to be whitish in color and is constant even when engine is hot. Engine was 2qt low on oil when I changed it and the tractor had only been mine for 1 month. Threw some seafoam in the diesel to see if that cleans the injectors and cleans out the smoking issue. The coolant tank was pretty dry but wasn't overheating and the oil light wasn't on. I topped off coolant and changed the oil too. No run time yet on oil change and coolant top off.
Am I looking at head, cylinder, or bottom end? Any ideas????
