L2900-sand in motor oil
Mike Gray
B7200 HST E, L2900 & LA480 Loader
Mar 21, 2022
Sarasota, FL
Hi I have a L2900 GST DT. Over the summer Mud Daubers (wasps) built a fairly large nest in the air filter housing. This fall when I started the engine, most of the nest went into the engine through air intake. I have flushed the engine oil 3 times using diesel oil motor flush and fresh oil each time. While I can't see any contamination, I'm not so sure it isn't there. So what are my chances of removing the sand if it's still in the oil or should I plan for an engine rebuild?
JasonW
563
330
Al
Have the oil tested. How did they make a nest past the air filter?
Also is yours a DT or a GST? Those are different machines.
L35
Jun 13, 2010
630
659
CT
If it got past the air filter (I don’t know how it would) it wouldn’t go into the engine oil. It would go into the cylinders which would then send it out through the exhaust.
9,447
Like @L35 said it wouldn't get to the oil that easily.
Does it start easy?
Does it smoke excessively when it runs?
Have you done a compression test?
9,447
You can have a GST in a DT, It is called a a DT-GST
3,677
OMG Stop. Just stop.
