I was bush-hogging my pasture last weekend, I cut the tractor off to take a break, when I cut the tractor off I noticed the ignition switch was warm but didn’t think much of it. When I came back about 10 minutes later the lights in the dash came on but the tractor would not crank or even turn over, there was a buzzing noise coming from under/behind the steering column, the lights on the dash stopped coming on a few minutes later. Since then I have been trouble shooting the problem, I have replaced the battery (was 7 yrs old), there is 12v on the red wiring to the ignition switch, the 40a fuses at the starter is good. After replacing the battery all lights on the dash started working, but still wouldn’t turn over. I noticed the glow plug light came on for a very short amount of time the first time I turned the ignition switch on, since then the light has not come back on. The dash lights have stopped coming on, It seems that when the lights on the dash stop coming on the flashers don’t work either. I think I have a bad ignition switch…..any suggestions?
