L2850 rear 24” rim plates
Selkirk_D
Kubota L245DT
Dec 5, 2024
Northern Idaho
So my L245 deal fell through, so I bought a ‘93 L2850. Has worn out 20” turf tires which I’m not a fan of. I’d like to switch to 24” ag tires, but “early” center plates seem to be scarce around here and somewhat costly . Will the later “B” style 6-lug plates work on my tractor? Will any other makes fit?
6,594
No, the B centers are not the same dimensions.
Contact @007kubotaguy and see if he has the rims you need.
You do Know you'll need to change the front rims too, or the ratio will be wrong.
Selkirk_D
Kubota L245DT
Dec 5, 2024
Northern Idaho
So apparently correct front rims are 16x7. The best I have found so far are 16x6 or 16x8. Will the 1” width variation throw off the circumference significantly? Seems like the faster rear tire wear would have a bigger impact
