L2800
2,581
Motor turns over
but will not crank
let's review,
when did it start last?
if a while, get all fuel out and replace with new
if just a few days ago - what has happened in the past couple of days? What if anything has been done to the tractor.
When you say it turns over - at a normal speed? Thus, this is cranking:)
You glowing the plugs?
Any smoke at all?
Bleed system?
Throw us the info ..... many people will chime in and help - we just need mo' info!:)
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Perhaps next time you could consider a different thread title, something like "L2800 cranks, but doesn't start"
Lencho
B7100hst
Jan 21, 2017
415
87
NM
Hi Bryan - welcome to OTT!
I am sure the people here can get you on the right track to fix your tractor. Just a bit more explaining of the symptoms is needed.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
482
409
Lake Almanor, Ca
I have the same tractor...so a more thourough explaination will help us advise you...
BTW...cranks and turns over are the same thing where I come from...
Are you saying it cranks...but won't fire?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Those are pretty simple. All they need is fuel and air to run. The more info you can give the better off you'll be.
